Ben, I believe I am have having a similar issue. I have multiple nodes on the suction side of pumps that are showing a SS pressure of 5.0 psi which is below the set residual pressure of 20 psi. As a result, the flex table return a result of "Available Fire Flow" = 0 for ALL zone junctions. I have placed the nodes in a separate zone and I am still getting the same fire flow results. Any thoughts?Thanks
Mark
Alex,
It looks like I gave you the wrong quick start lesson. Have a look at the one titled "Extended Period Simulation". In step 11 it shows how to setup a the 3 hour pattern. If you haven't gone over the over quick start lessons these are a great place to start learning about the software. You can also go to our technotes and FAQ page found here
and have a look at the wikis we have listed under the WaterGEMS/WaterCAD section. Another good place to start for a newer user is learning and resource guide that puts a lot of this information together in one location. That can be found here:
