Hi
I have a model in watergems. I have asked a question about before. But I have two other questions, which decided to say them in a new post.
First, as I have taken all the errors, and it seems that all details work correctly, I noticed that the direction of the flow is inverse the one that should be. It means that flow conveys from downstream to the well pumps. What is the reason of it?
Secondly, I replaced my reservoir with a node to balance the amount of flow I desired. Then I gave the demand I wanted from each well to the node right after that well. I have to give some demand to the node which is represented for the supply reservoir in order not to be removed from the model. But the demand is added to the total demand of wells. I gave it a little amount, but I'm not sure if it is true. And the question that does the amount of demand given to the supply reservoir effect on the direction of the flow?
I upload my model here.
WTG 2K 4W GE NP 435 5.zip
Thanks for your help.
Zeinab
Mark
Answer Verified By: Zeinab Amiri
