We are using the Water GEMS V8i (Select Series 5). In one of our project, we are checking the adequacy of existing transmission main with existing pumps. In Water Gems, We have modeled the pipeline & pumps as per existing data like Pump Flow & Head and also all other details are filled properly.
While doing above analysis, we are getting the different Total Flow and Head in Output file (Flex table of Pumps).
In view of above results, kindly explain, why the both input & output data are not match.
Please refer attached screen shot
Arun V
Mark
