Extra junction point
I have marked network in water Gems by using Model builder. That was existing pipeline data in shape-file formats. Now I'm facing problem of extra junction point which i don't want I.e. J1 to J2 is 400mm of 50m length pipe and J2 to J3 is also 400mm of 150m pipe. So now i want to remove J2 and need J1 to J3 400mm of 200m pipe. Is any tricks to remove directly?  In This model lots of extra junction are exist  and that i don't want.
  • Prash,
    Check out Skelebrator,under the Tools menu. This will simplify the network, reducing the number of pipes while maintaining hydraulic equivalency. You can read more about it in the help.
    Jesse Dringoli
    Bentley Systems, Inc.
