In Bentley WaterGEMS SS5, could I back skeletonized model into Original model. I consider that when main pipe calibrated precise roughness..., back to original model will reflect more accuracy, especially for fire hydrant tests, then it could be continuously developed.
Thanks in Advance!
Answer Verified By: dang tran.
To add to Scott's response, here is an excerpt from the WaterGEMS Help topic "Skeletonization":
Different levels of skeletonization are appropriate depending on the intended use of the model. For an energy cost analysis, a higher degree of skeletonization is preferable and for fire flow and water quality analysis, minimal skeletonization is necessary. This means that multiple models are required for different applications.
