Hi
I have an existing culvert and I need to extend it with different dimension as it shown in the figure below.
In culvertmaster , first I created a file for analysing the existing system but my question is for modeling the extension of the culvert what should I do . Should I create a design file and if I do that how many culverts should be defined for new condition (existing and extension part)?
To model culverts in SewerGEMS, we have introduced new element since SewerGEMS SS4, which is headwall. You can use headwall as the connecting element to model the culvert in SewerGEMS.
Here in the technote on Headwall, please go through it.
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/16005.headwalls
This also might be helpful for you
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/12756.is-it-possible-to-model-a-culvert-in-stormcad
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Jesse Dringoli
