Hi, im receiving an error everytime i try to split the new pipes in my model. This problem seems to only occur in any new pipes that was added. The older pipes that was created earlier seems to split just fine.
This problem seems to only occur on this specific model. Any fix for this? Could it be that one of the watercad files (dwh. or something) is corrupted?
Please try to compact the database, to see if that helps.
If this doesn't help then we would need a copy of your model.
There are two options for sharing your model files on Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
communities.bentley.com/.../7079.be-communities-secure-file-upload
If you send the model, please post here so we know it is available.
Also please let us know , which software are you using and the version of it.
Sushma Choure
Bentley Technical Suppport
