Hi
What is difference between 'Duration of Pipe Failure History' and 'Duration of Pipe Group Failure History' in Pipe Break program? (In fact I do not know what 'Pipe Group' is here exactly. Please explain it more that Help).
Thanx
Terry FosterTechnical SupportHydraulics and Hydrology product lineBentley Systems, Inc.
Here is a support solution that you may find helpful on Break Analysis: communities.bentley.com/.../running-pipe-break-analysis
When do we use Pipe Group in Break Analyze? What is Pipe Group good for? My conjecture says when we know a break has occurred in the network, but do not know in which pipe, then we define a Pipe Group in which we know the break has occurred. Am I right? When do we use Pipe Group else?
Meanwhile assigning each Pipe to a Pipe Group is compulsory and computing the analyze needs it to be done. Why does not it (defining a pipe group for all pipes) optional?
Thanx in advance for your response.
