I am having a problem with my static WaterCAD model as follows:
I have two sites, let's call them Site A and Site B. Site A is being supplied by a reservoir + pump combination. Site B is being supplied by a tank. Site A is at a lower pressure zone that Site B.
Site A is connected to Site B by a supplemental pipe connection. The flow only goes through the supplemental pipe connection from Site B to Site A (higher pressure zone to lower pressure zone) when the Site A reservoir + pump combination cannot supply a minimum pressure to the Site A system. When flow goes through the supplemental pipe connection from Site B to Site A, I also need to maintain a minimum pressure in Site B so that the supplemental flow needed for Site A does not adversely impact the pressure in Site B.
I have modeled the supplemental connection with a PSV and PRV. The PSV maintains the upstream pressure (i.e., Site B). Downstream of Site B and the PSV is the PRV. The PRV boosts the pressure in Site A. So, in order of the direction of flow, it is: Site B to PSV to PRV to Site A.
I modeled the setup step-by-step by first inserting the PRV only (no PSV). The model to runs as expected when I only have Site B to PRV to Site A. This model provided the minimum pressure needed for Site A by drawing from Site B.
Next, I inserted the PSV with a pressure setting of 0, meaning that the valve is always open, to test the setup. I run the scenario, and the model is giving me two error messages saying that 1) PSV cannot supply pressure and 2) PSV caused ill-conditioning. Any other pressure settings above 0 also gives me this error.
Any help with what I am doing incorrectly would be great.
If you would like us review the model, then please upload the copy of your model. There are two options for sharing your model files on Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley. communities.bentley.com/.../7079.be-communities-secure-file-upload If you send the model, please post here so we know it is available.
Sushma Choure
Bentley Technical Suppport
