I have a static WaterCAD model. The model has multiple scenarios referencing a common calculation option. When I run all of the scenarios, two of the scenarios is giving me a "Network Unbalanced" user notification.
I have check the model inputs, desired results, and the model setup, and I think everything is built correctly. I have increased the number of trials to 10,000 and decreased the accuracy to 0.01. At this point, what other options are there to force the model to balance?
Thanks.
Hello Harry,
Here is the technote on network unbalanced issue, which you may find useful.
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/8769.watergemswatercad-user-notification-network-unbalanced
If that doesn't help then we would need a copy of your model, to help you with the issue.
There are two options for sharing your model files on Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
communities.bentley.com/.../7079.be-communities-secure-file-upload
If you send the model, please post here so we know it is available.
Sushma Choure
Bentley Technical Suppport
I computed the child scenario RW 1.2, it didn't give me any error about network unbalanced.
I tested it in WaterCAD SS5.
What is the version of WaterCAD that you are using?
