Hi
When I import LandXML file it shows the error " Less Than Three Pints in DTM"
Please let me know what's wrong with that.
Hamid
Hello Hamid, What is your SewerGEMS version number? (check Help > About) First, can you confirm that the LandXML file contains valid contour lines? If so, the error you mentioned matches a known issue we recently addressed in SewerGEMS V8i SELECTseries 5 (08.11.05.58) that effects certain DTMs. Providing a copy of the LandXML file would be helpful. There are two options for sharing your model files on Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley. communities.bentley.com/.../7079.be-communities-secure-file-upload
Drainage Existing Condition.zip
Hi Jesse
You can find the file from attached.
Also, I am using the Select Series 5 -version 8.11.05.58
Sushma Choure
Bentley Technical Suppport
