Hey all,
I'm pretty new to WaterCad and I am having some issues with the fire flow and hydrants in the model I'm currently working on. I set up my system (with hydrants). In the Alternatives window I created a fire flow alternative (including a velocity upper limit as well as needed fire flow, fire flow upper limit, and pressure constraints). But for some reason when I run the model the fire flows are not being added to the system. When I look at the flow coming out of my reservoir the only flow coming out is the base demand that I applied to all my junctions.
I'm not sure what I did wrong but I think it either has something to do with my hydrants or the way I set up my fire flow. Does anyone have an suggestions as to how I can fix this?
Thanks in advance!
Terry FosterTechnical SupportHydraulics and Hydrology product lineBentley Systems, Inc.
