I am running StormCad SS 4 in Microstation SS2 with a large, but simple system of catch basins, manholes and pipes. All ran fine until I had to add some catch basins mid pipe and change other catch basins to manholes. now the model will not validate. I get an error not found in Help; "Grate Width must be greater than zero". I am only using the inlet catalog library and have not changed anything from when the model ran until now. I have checked the library and it is fine. I cannot find grate width anywhere else. Has anyone run into this and found an answer? I have opened the StormCad model in the stand alone version and tried validating it and got a different error; "A software error has occurred...". I have closed and opened the program several times and restarted my computer a couple times and still get the same error. I have a service ticket in with Bentley, but have not heard back yet. Thanks.
Craig Calvin
Bentley Technical Support
