Can Sewergems identify the breakdown of different flow types in a sewer pipe such domestic and industrial flows?
When the flow enter the flow through manholes, its counted as total flow of all the sanitary loads type like, domestic or industrial.
However, you can differentiate the flow entering into the manhole as inflow(wet) collection maybe as industrial flow and sanitary(dry weather) flow as domestic flow.
But when in the results, the total flow is calculated which is addition of differnt types of flows.
Are you looking for a way in the results of the pipe, so that it will differentiate/mention which type of load is that?
Sushma Choure
Bentley Technical Suppport
