Hello everyone
I have a problem with my simulation because I don’t reproduce the discharge pressure using “Periodic head-flow”. I’ve noticed that viscosity is fundamental for the network, logically when I changed the viscosity the discharge pressure changes, however this change is not lineal, it is like a parable, it been not logical, I tried with other fluids and the behavior is lineal how I expects. I hope someone knows something.
Thanks.
Hello Lyanne,
In order to answer this, a bit more information will help.
1) I assume you're using HAMMER. What version are you using? You can find this under Help > About HAMMER. The latest is 08.11.06.58 (SELECTseries 6)
2) When you say you "don't reproduce" the discharge pressure, what exactly do you mean? Are you comparing to some field measurements? There are any number of differences between the model assumption and the real system that can cause differences.
3) What exactly does this Periodic Head-Flow element represent?
4) When you say "discharge pressure", are you looking at the pressure at the periodic head-flow element during the initial conditions, or something else? (max pressure during transient simulation?)
5) You mentioned that you did not see this behavior with other fluids. Can you be more specific as to exactly what parameters you're varying?
6) Can you provide a copy of the model for review? There are two options for sharing your model on Communities. Either way, be sure to zip your files first. The first option is to attach to your reply on the forum using the Advanced Reply Editor (see link below and to the right of the reply box). If your data is confidential, use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
http://communities.bentley.com/help/w/be_communities_help/7079.be-communities-secure-file-upload
Original TPC-ICAMOR (DCOM).wtg_1_1 (2).zip
5852.Original TPC-ICAMOR (MEREY).wtg_1_1.zip
1) I’m using Hammer Bentley V8i SELECTseries 5.
2) By reproduce, i mean to simulate. I need to simulate the discharge pressure in a displacement positive pump that exists, I have the network in other simulator where I evaluated the steady state and I got the pressures I expected. Now I need to reproduce that network using Hammer. I know that exists a difference between both simulators but using Hammer the viscosity has a totally different behavior at the same initial conditions. that is not expected because I worked with the same fluid in both softwares.
3) I want to simulate displacement positive pump.
4) I’m looking at the pressure at the discharge of the periodic head- flow during the initial conditions.
5) I have two fluids that I need to evaluate in the same network, both are crude 16°API( a) Merey16°API, b) DCOM 16°API). When I run the simulation with the first crude, this doesn't presents any problems but using DCOM 16 it does. I’m only changing the fluid specifications in the simulation (viscosity, temperature, vapor pressure, gravity specific, the wave speed and the discharge coefficient of control valve at the end of the network)
6) Yes, of course. I sent two simulation for the both fluids. For the first one "Merey" the discharge pressure at the periodic head-flow should be 750psi, while for the second one "DCOM" should be 577psi.
