Hi to all,
In my project, because of dry condition I suppose virtual flow depth, LPI Coefficient, NR weighting coefficient, Relaxation Weighting Coefficient, NR Iterations, Computation Distance and Calculation Time Step in order equal 0.004 m, 1, 1, 15.2 m and 0.025.I attached graphs. I don't know exactly where is the boundary between the virtual and real water in flow graph?
The amount of virtual flow that the numerical model applies in the dry flow condition is very small and is invisible with no practical impact on the computational results. It adds a small base flow to every conduit which has a depth < the virtual depth value that you enter in the calculation options.
Here is the link to the support solution about virtual depth.
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/22527.virtual-flow-depth-solution-500000063442
If this doesn't help then , you may want to upload a copy of your model for our review.
There are two options for sharing your model files on Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
communities.bentley.com/.../7079.be-communities-secure-file-upload
If you send the model, please post here so we know it is available.
Sushma Choure
Bentley Technical Suppport
