My model consists of 5 pumps in a pumping station with a lots of piping. Every node was placed perfectly in the correct axis in order to use the "Calculate Transient force" option. Everything is running well. Results are logic, except for one node where I have a surge valve. There are two parallel lines running, one on top of another, and they connect at each end. Each line has a surge valve on it. Wheter I run scenarios where the surge valves open or not, I get the same problem. The valve on the top line sees a force in Y, which I expect since the pressure from the water in the pipe is pushing that way. The valve on the bottom line does not see a force in Y. I would expect it to since it is subject to the same pressure and placed in the same axis as the other valve and I do get a Pressure Result for that node. Both upstream and downstream nodes of the surge valve see forces in the expected axis, including the Y axis. Any ideas?
Answer Verified By: Normand Chabot
