I am developing a modle and I found the flow supplied is 0 L/s when I uses the function of "Compute Initial Condition". Could anyone tell me why occured 0 L/s, did I make any mistakes when I am processing the program? and the picture is enlisted below.
Thank you in advanced
Best,
Chenfei
Sushma Choure
Bentley Technical Suppport
Also, here's an article that explains a bit more about the difference between flow supplied, demanded and stored:
Flow Supplied vs Flow Stored vs Flow Demanded and Flow(In) vs. Flow(Out)
It sounds like you may not have a reservoir, which is not necessarily a problem. It's possible you may be simulating flow by gravity between tanks.
If you need further help, you can provide a copy of the model. There are two options for sharing your model on Communities. Either way, be sure to zip your files first. The first option is to attach to your reply on the forum using the Advanced Reply Editor (see link below and to the right of the reply box). If your data is confidential, use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley. http://communities.bentley.com/help/w/be_communities_help/7079.be-communities-secure-file-upload
