How to import contour data or elevation in stormcad?
Formats available : DEM, Contour DXF, XML,
Please help me regarding this..
Thank you.
Sushma Choure
Bentley Technical Suppport
Thanks for the advise.
But while importing i am getting some error like "All elements in the model fall outside the scope of DEM" how do i solve this error?
It would be really help full if u would suggest me some link or any video where i can get the detail steps to be followed while importing the contour data.
Thanks for the reply scott. I tired changing the units but i am still facing the same problem.
I am attaching the file which i want to open in Stormcad so that u can help me out with this issue and guide me for the changes to be done.The file is in DWG format (Autocad civil3d)
Z1-Area1.dwg
Thanks & Regards
Deepraj
