I'm getting the following error "Engine Error Message: CalcTable.ID is 0: FRMPONDDIVERT" when I connect my pond outfall to a pond 2000' downstream via a ditch/channel.
I have a pond with two outlets (an orifice, and a weir wall), this pond outfalls into a 2000' long channel before it enters a different pond. I have the pond outfall modeled as a junction element and linked by a trapezoidal channel to the next pond.
Photo 1: Proposed Conditions (Error occurs)
The image below shows the existing conditions where Pond US Weir does not exist. Pond US Weir is being proposed. When I run the existing model I dont get the error message, and everything works fine. Does anyone have any ideas why I am getting this error in the proposed conditions? Basically I want to connect the two ponds in the proposed conditions by a ditch. Outfall from Pond US Weir will eventually make it downstream to Ponding US.
Photo 2: Existing Conditions (Error does not occur)
