Dear Sir,
I am confused on how to model my pump using watercad since my pump varies between 1st and 2nd day ( 2 scenarios of pumping). so I model my pump as a pattern but the problem is that I need my pattern cant exceed 24 hrs !!!
My pump pattern is as follows:
So how can I run my system so that the number of pumping is as follows ??
Moreover, I am also confused by watercad when I insert a tank level control, I have one for the high level ( when the water tank is full, the pump will turn off automatically) but how can I know when it will work again ?did it work directly after reaching the limit or there is margin ??
I look forward to touch my questions and confuse and have a reply,
Thank you
Mark
In my testing, a pump pattern can extend to 48 hours and will repeat. See example below.
If you want to use controls instead, you could incorporate a variable using a "dummy" pipe that you close and open, similar to what you see in this article. Basically day 1's controls would include a condition of the pipe being open, and then have an action for the last control of the day to close the pipe, then day 2's controls would have a condition of the pipe being closed and have an action for the last control of that day to open the pipe.
