Can anyone share the PumpSelectionStart.wtg example for me, i didn't find it on this path its missing. C:\BentleyWorkshop\WaterDistMetric\Starter.
kindly share it for me.
Hello Adnan,
Can you confirm which workshop you downloaded? The dataset should be included but we've recently noticed some problems with this and have been working on updating them. Did you download the SELECTseries 3, metric version of the "Pump Selection" workshop here? -
In our testing, the metric version (second link circled above) contained the dataset within the zip file. When you download the file, be sure to extract the folder within, which contains the workshop model files including the one you need for this workshop.
In the contents of the ZIP file, you will see the PDF and another ZIP:
Within the file WaterDistDesignAndMod_Dataset_SI_V8i_SS3_Feb-2012.zip, you will find the workshop dataset - extract this file to your C:\ drive.
