I have been developing a model with many graphs that compare Time Series Field Data to model results. When I first created the graphs the software consistently formatted Time Series data as points and model results as lines. The model has recently started formatting some, but not all, graphs with the opposite display.
Is there a way to set all graphs to show Time Series data as points and scenario calculations as lines?
*Note that this change occurred after upgrading software from SELECTseries 5 to the latest version of SELECTseries 6.
Hello Andrew,
Try this:1. Open the model and compute.2. Open or create a graph containing both time series field data and calculated results.3. Open chart options, select the time series field data, click change, then select the style "Points" using the TeeChart Gallery. Set the calculation series to use the style "Line".Alternately, you can select the series section, select the format tab, click the Border button and toggle Visible. Point visibility can be toggled in the Points tab.4. Close chart options and the graph is updated to display the time series field data with points and without lines. 5. Select "Save Chart Options As Default".6. Close the graph.7. Open another graph8. Select "Apply Default Chart Options" and the graph should update the graph to show time series field data as points and calculated data as lines.
Note: There was a patch released for SELECTseries 6 (08.11.06.58) that addressed two defects related to graphs (#289570 & #290223). That could be the reason for inconsistent results between SELECTseries 5 and SELECTseries 6.
Craig Calvin
Bentley Technical Support
Please provide the version you are currently using and your model files. You can find the version number by opening the Help menu and selecting About WaterGEMS. It will be on the bottom left corner of the dialog (08.11.06.XX).
There are two options for sharing your model on Communities, whichever you choose please be sure to zip your files first. The first option is to attach the zip file containing your model to your reply on the forum using the Advanced Reply Editor (you'll find the link below and to the right of the reply box). If your data is confidential please use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley employees. Please be sure to reply on this thread with the name of the file after it has been uploaded.
http://communities.bentley.com/help/w/be_communities_help/7079.be-communities-secure-file-upload
Thanks, Craig.
The file has been uploaded with the title "Suez - Harrisburg Model.zip"
Software version is 08.11.03.113 (64-bit)
Andrew
