I'm trying to connect two headwalls with a channel, I believe this is done in civil storm by using a conduit and defining the section type as rectangular, or trapezoidal. When I display the properties it will not let me change it to anything but a circle? Is this the correct way to do this or is there other ways?
When you say "it will not let me change it to anything but a circle", do you mean that Circle is the only option listed for you, or do you receive a user notification when computing with another section type selected? If you are receiving a user notification, what does it say?
Here are a couple of related wikis.
Headwalls
Conduit vs. Channel
Please provide your model. There are two options for sharing your model on Communities, whichever you choose please be sure to zip your files first. The first option is to attach the zip file containing your model to your reply on the forum using the Advanced Reply Editor (you'll find the link below and to the right of the reply box). If your data is confidential please use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley employees. Please be sure to reply on this thread with the name of the file after it has been uploaded.
http://communities.bentley.com/help/w/be_communities_help/7079.be-communities-secure-file-upload
Craig Calvin
Bentley Technical Support
There are other options for me to select, but if selected it just goes back to circle. Attached is the model I was working on.
existing.zip
Mark
