Ref: http://communities.bentley.com/products/hydraulics___hydrology/f/5925/t/119049
Thanks Mr. Scott Kampa & Craig C. This help alot. Now one more problem is left which is " Section size is not selected or not available" and i have tried to add section size in flex table using globle edit but is showing error i. e. unable to globel edit there are no item are avialable for "size".
From your previous thread's screenshot, it looks like you're using SELECTseries 5. This version uses the Catalog Class feature. If you want to use Automated Design to size conduits, make sure to set them all as catalog conduits and select the catalog class and initial size per this article. Make sure you have at least one catalog class configured under Components > Conduit Catalog.
