Friends,
I am using Bentley WaterCAD V8i Select Series 6, with version 08.11.06.58 64 bit version.
for a project I am developing a water model for a small county in Sweden and I am unable to load a background picture when I save the file in AUTOCAD 2013 dxf format.
Is this a compatibility issue?
Please assist.
Tushar Pratap Singh
Mark
If you are indeed encountering an error when attempting to load the DXF as a background, knowing the exact error would help, but you can also try the following articles from our wiki if they match the symptom:
Shapefile or DXF background "invalid or corrupt" error
The specified module could not be found (Exception from HRESULT: 0x8007007E)
If the DXF simply does not appear in the model, check this article:
When importing a DXF as a background, it does not show up in the model, even when pressing zoom extents.
