I have a horizontally laid pipe network that runs in a flooded stage set by weirs. Since StormCAD does not have the option to place weirs I have set a tailwater (at the weir crest plus the head) to run my analysis. The results I am getting from the program show zero velocity and a constant HGL for the majority of the system.
Beside optimizing he pipe network (using smaller pipe sizes), is there anything in the base calculation options that I can change? Am I missing anything?
Thank you in advance.
Mark
Answer Verified By: Scott Kampa
