"I'm running StormCAD V8i and while I can add wet wells, pumps and pressure pipes to my network, I cannot specify pump characteristics as there is no "Pump Definitions" field under the "Physical" section of the Property Editor. Is the pump modelling feature confined only to applications such as SewerCAD?
Mark
Answer Verified By: Scott Kampa
