1. In CivilStorm, why can't I connect a pond outlet structure to an outfall? I am just try to do a classic detention pond design as the pond outlet via a box culvert with a weir on top, and outfall downstream of the culvert.
2. I got a error message "The referenced Culvert Barrel Shape does not match the conduit" if I set "no" to control structure and have a pipe downstream of the outlet structure to a headwall.
3. Civilstorm keeps crashing on me when I select the outfall symbol.
4. Some of my profile results time steps jumped from 0 to 24hr without showing any results in between.
Please advise and help. If Bentley can discuss with me, that would be wonderful. thanks.
For item 1. Thank you.
Please upload a copy of your model for our review.
There are two options for sharing your model on Communities, whichever you choose please be sure to zip your files first. The first option is to attach the zip file containing your model to your reply on the forum using the Advanced Reply Editor (you'll find the link below and to the right of the reply box). If your data is confidential please use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley employees. Please be sure to reply on this thread with the name of the file after it has been uploaded.communities.bentley.com/.../7079.be-communities-secure-file-uploadIf you upload the model to Sharefile, please post here with the name of the file so we know it is available.If you upload the model to Sharefile, please post here with the name of the file so we know it is available.
Sushma.
Sushma Choure
Bentley Technical Suppport
