Dear Mr.Jesse Dringoli
Depending on ground elevation, it may be impossible to keep pressure below 60 m and depending on loading, there may be some pipes with velocity below 0.3 m/s. Before you even think about using Darwin Designer, you need to run many simulations for many scenarios to get an appreciation fro realistic values for inputs and constraints.
Mark
