How do I add a .sid image as a background layer in WaterGEMS standalone?
Sid images are supported as background layers according to Help, but there is no sid option when you try to add a new file (standalone). What am I missing?
WaterGEMS V8i select series 6 08.11.06.113 64 bit
This post also states this is available in standalone. Help doesn't specify standalone or ArcGIS mode.
communities.bentley.com/.../23670.what-file-types-are-supported-for-background-layers-in-standalone-solution-500000090560
