Dear All, I have this file that I am trying to open but keep getting the below error.
I have tried importing, compacting and opening only .sqilte and starter file with no success.
It happened with two different files so I am guessing the problem is with my software (SewerGEMS v8i select series 4) ?
Any help will be appreciated !
Hello Jihad,
Please go thorugh the below mentioned support solution, to see if that helps.
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/15915.error-opening-existing-model-parameter-name-index-was-out-of-range
If none of these helps, then it might be a possibility that the model that you are trying to open is saved in the higher version of the software than you are having.
Check the version number of the software , in which the model was created using the link mentioned below, to see if that higher version than you are having.
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/7502.locating-the-version-number-of-the-software-a-model-was-created-using
If that is the case then , you may want to upgrade to the latest build of SewerGEMS, or to the version in which the model is created.
Sushma.
Sushma Choure
Bentley Technical Suppport
