I'm working on a combined sewer model, using SewerGEMS. I'm trying to determine the maximum sanitary load that we can add before the pump station overflows during a rainfall event. My problem is that there's a difference in the flow entering the pump station when I try to put the inflow at different nodes in the sewer system. The flow entering the pump station is bigger when the inflow is far from it. The sanitary load is fixed. Does anyone know why the model reacts like this?
Thank you
We would need a copy of your model, to see how the model is set up.
There are two options for sharing your model on Communities, whichever you choose please be sure to zip your files first. The first option is to attach the zip file containing your model to your reply on the forum using the Advanced Reply Editor (you'll find the link below and to the right of the reply box). If your data is confidential please use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley employees. Please be sure to reply on this thread with the name of the file after it has been uploaded.
http://communities.bentley.com/help/w/be_communities_help/7079.be-communities-secure-file-upload
Sushma Choure
Bentley Technical Suppport
