i have two reservoirs ,junctions and one pump delivered water from R1 to R2 levels of it as flowing
junctions levels
Label Elevation (m)J-1 110.00
J-2 120.00
J-3 130.00
J-4 120.00J-5 115.00
reservoirs levels
Label Elevation (m)R-1 100.00R-2 110.00
pumps levels
Label Elevation (m)PMP-1 99.50
when i make run and open pump system curve i found water gems calculate when Q=0 H = 10 its difference between two reservoirs but H must me static head in water line calculated as ( max level in system - pump level )in this example must be when Q=0 H=130-99.50=30.50 m system curve is very important in hydraulic analysis as its control flow in pipe and delivered head from pump
The system head curve is the difference in head across the pump required to move water at the corresponding flow rate. In the case when Q=0, the system head across the pump is 110 - 100 = 10 m. See any hydraulics book for an explanation of this. It's page 45 of out Advanced Water Distribution System Modeling and Management book. The elevation of the pump makes no difference in determining the system head curve (as long as you have adequate NPSH).
i know what you want to tell me but i have problem that water gemc or water hammer produce head and flow depending on system curve and cross of with pump curve therefore it should be take the levels of all point with any condition i entered air valve or not and i cant make downward pipe so small because friction losses is calculated depend on diameter
