I am analyzing pond in urban storm network design. While designing, i have taken Elevation-Area volume type and initial elevation kept at invert, but it gives me error like "For elevation-area volume type, the elevation-area curve is missing. There must be at least 2 points in the curve" though i have provided values for elevation & area. Total network design is stuck at this position only due to this error.
Thanks & Regards,
Namita
Please provide the model files (*.stsw, *.sqlite). There are two options for sharing your model on Communities, whichever you choose please be sure to zip your files first. The first option is to attach the zip file containing your model to your reply on the forum using the Advanced Reply Editor (you'll find the link below and to the right of the reply box). If your data is confidential please use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley employees. Please be sure to reply on this thread with the name of the file after it has been uploaded.
Craig Calvin
Bentley Technical Support
