Hello Bentley community,
I am working on calibrating a large water distribution (~1000 pipes, 9 reservoirs, 14 pumps, wells, etc...) system in WaterCAD. We have done flow testing at 16 different locations throughout the system and have SCADA data for many of the reservoirs and pumps for each minute of the day of flow testing. The model provided currently has none of the SCADA infrastructure modeled, but I want to use the SCADA data to help set reservoir levels, pump flowrates/discharge pressures, etc... for the field data snapshots in Darwin Calibrator.
Is there any way to import the SCADA data into the model so that Darwin calibrator will know the data from SCADA at the time of each test? I would like to avoid entering the data manually as this would take many hours (~20 SCADA elements per three data snapshots per 16 tests.)
Also, is there a way I can tell WaterCAD to adjust the roughness for each pipe individually, other than giving each pipe its own roughness group? (another task that would take hours.)
Is it recommended to run 16 different calibration runs, or one large run?
Thanks in advance,
James M.
Hello James,
You can import the SCADA data into the Darwin Calibrator directly, as shown in the below screenshot. You need to define the SCADA connection in the model first.
Please note that, in order to calibrate a model, Darwin Calibrator makes adjustments to the pipe roughness, demand, and/or element status, provided you have entered the demand and roughness data in the model first.
Please see the below technotes on Darwin Calibrator and SCADA Connect, which you may find useful.
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/5910.using-darwin-calibrator
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/24272.scadaconnect-simulator-for-watergems-v8i-selectseries-6
Sushma Choure
Bentley Technical Suppport
