Dear Jesse,
Thanks for your earlier reply. it really helped me. but now i am facing another problem. when i am modelling a ground storage tank in rising main, it effects the hydraulic grade line of all previous nodes. how can i avoid this.
and if i change the elevations to higher elevations (which are not the actual ones) its make impact and negative pressure changes to positive pressure. how can i avoid the effect on previous node because i have free falling water to ground storage tank.
Suhail Latif
Sushma Choure
Bentley Technical Suppport
4382.1780.Model.rar
Reply from Suhail , posted by mistake in a new post -
Hello Ms Sushma,
i am attaching the model for your review. actually tanks affecting the hydraulic grade line of previous nodes, if i removed the tank the i got very smooth line. tank is under ground tank and inlet is on top. so it should not affect the previous nodes .
