In watergems , a model is defined with input source as tank and gravity distribution network with junction demand (actual gravity free flow to sump) . After fixing for pipeline diameter and required head at Junction, I wish to find out actual or realistic flow from end junction , as in few nodes, residual head is more than (say 20 to 35 m.)required head as 5 m. I have tried model with Discharge to atmosphere in place of Junction, but not clear with typical flow and pressure drop input. I have gone through various post but not getting proper result. Kindlly suggest/
Could you please explain bit more about the issue, are you trying model free outfall at the end?
If you have already tried the Discharge to Atmosphere Element, best for such situations, what challenges did you face in that?
If required, you can upload your model files.
There are two options for sharing your model on Communities, whichever you choose please be sure to zip your files first. The first option is to attach the zip file containing your model to your reply on the forum using the Advanced Reply Editor (you'll find the link below and to the right of the reply box). If your data is confidential please use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley employees. Please be sure to reply on this thread with the name of the file after it has been uploaded.
http://communities.bentley.com/help/w/be_communities_help/7079.be-communities-secure-file-upload
Sushma Choure
Bentley Technical Suppport
Astol zon 5c.rar
Hello Devang,
As mentioned is my previous post, discharge to atmosphere is the best option is your case for modeling the free discharge.
Here is the technote on discharge to atmosphere element.
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/19581.how-does-watergemswatercad-treat-the-discharge-to-atmosphere-element
Since you have finalized the head, you should use method 1 to solve for flow to get the maximum flow.
Have you tried any of these methods? Do you have any field data since this is an existing system to compare the results with?
