I would to know how to create a list of materials.Thanks
Hi Gabriel,
Could you please be more specific.
Do you want to create a list of materials available in the engineering libraries?
Do you want to create a report which lists what material each pipe is?
If so, you could do this by creating a report from a FlexTable. See the following article for more information.
Customizing FlexTables for viewing and reporting data -- Moving, adding, and removing columns
Craig Calvin
Bentley Technical Support
You may also want to check out Pressure Pipe Inventory under the Report menu.
I would like to know how to create a list of material calculated hydraulic network. The list would have specifications like, amount of Te, Cap....Thanks
I have merged the new thread that you posted today, into the old one that appears to be on the same topic.
To confirm, when you say "Te, Cap", are you referring to fittings on the pipe? (minor losses) If so and if you've selected "False" for "Specify local minor losses" and entered them in the Minor Loss Collection, see the below article:
Reporting Details of Fittings (Minor Losses) for Each Pipe
If this does not help, please provide a bit more detail on what you're looking for. You may also want to look at OpenUtilities.
