I'm using Scada element in Sewergems to compare my results with field data. Unfurtunately when I graph all my Scada element only 24h is shown but the calculation options are set to 48h. I'm using SWMM solver and end date\ end time for duration type . I looked at the data in the graphs and there is 48h data (see below).
Do you know why ?
Thank you
Marie-Joelle
I am not able to see the graphs you mentioned.
Please provide the model files (.stsw, .SQLite), the screenshots you mentioned, and the SCADA data source for testing. There are two options for sharing your model on Communities, whichever you choose please be sure to zip your files first. The first option is to attach the zip file containing your model to your reply on the forum using the Advanced Reply Editor (you'll find the link below and to the right of the reply box). If your data is confidential please use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley employees. Please be sure to reply on this thread with the name of the file after it has been uploaded.
Craig Calvin
Bentley Technical Support
Take a look at the FAQ at the bottom of the following article titled "I can see the graph in SCADA Signal Editor but not in the Graphs, how can fix?".
SCADAConnect in SewerGEMS
2 years ago to solve this problem, I had to use SewerGEMS 32 bits version and Excel 1997 version as historic file Scada Element. I’m now using Sewergems (CONNECT Edition) 64 bits and Excel 2010, and I have the same problem : when I graph a Scada element only 24h of the historical data is shown but the entire simulation results are shown (48h). I’ve checked the dates, start/end simulation time.
Do you know why ? Is there a way to solve this problem ?
Thanks !
