Hi,I have a pretty simple question. Is there a setting to control the minimum relative speed factor for a variable speed pump? Currently the pump drops down to about 0.36 relative speed factor with a flow of 0 gpm. This is not realistic and would like the pump to stop decreasing speed when it reaches .67 relative speed ( i.e. 40hz/60hz = 0.67).
Thanks in advance.
