I imported a model using CAD file (dxf). There are 243 orphan nodes in the network - nodes that are just hovering above pipes. I tried select all and split, but it doesn't work. What could be going wrong? Another person asked this question on forum, but that question is marked as resolved without explaining the solution.
Hello Pankhuri,
Please take a look at the article below.
In the water products, junctions appear to overlay a pipe instead of connecting to it
Craig Calvin
Bentley Technical Support
Answer Verified By: Pankhuri Agrawal
If you still have issues with the workflows in the articles I provided, please upload your model files and dxf file for testing. What product and version are you using?
There are two options for sharing your model on Communities, whichever you choose please be sure to zip your files first. The first option is to attach the zip file containing your model to your reply on the forum using the Advanced Reply Editor (you'll find the link below and to the right of the reply box). If your data is confidential please use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley employees. Please be sure to reply on this thread with the name of the file after it has been uploaded.
http://communities.bentley.com/help/w/be_communities_help/7079.be-communities-secure-file-upload
