I am currently working in the same project described in this two threads that my teacher did when she was working in her masters degree thesis and wasn't able to finish it for time reasons:
http://communities.bentley.com/products/hydraulics___hydrology/f/5925/t/100796#pi20068filter=all&pi20068scroll=false
http://communities.bentley.com/products/hydraulics___hydrology/f/5925/t/100798
Basically what the program tries to do is to run an optimization model and then analyze the results in HAMMER.
Right now I'm experiencing an issue with the LicensingFacade.dll, but everytime I use it this error appears "The Specified module could not be found (Exception from 0x8007007E)". I tried doing what the note in the WO.NET programming guide says:
"Note: standard procedure if you receive errors or warnings, or are unable to obtain a license for unknown reasons, is to first run the License Management Tool. Use Tools-Options to double-check the SELECT Server Settings. Then use Tools-Send Logs Now."
But the problem still persist. I am using the Student license that my university provides me, so I can't access the Bentley Developer Network community where I have read this kind of threads are handled.
Also, can it be an issue that I'm working with the same WaterObjects.NET that my teacher used 2 years ago? If so, what can I do to get a newer version?
I'll be gratefull with any kind of help, It's been weeks since I'm stuck with this problem.
Juan Sebastian.
Mark
Answer Verified By: Juan Sebastian Gómez Pinto
