Hello
I'm doing a simulation based on the rapid closure of a valve ball, but I have some problems pressure drop is not as expected. I pretend closing it with a pattern of operational valve. my question is if corecto for such situations indicate the valve closure by a pattern or perhaps better control. because using the pattern gives me a sobresión 10m when I experimentally comes only 5m. My scenario has two types of pipe not know if that also affect the calculation of wave speed.
I would greatly appreciate if you can guide a bit.
Hello Claudia,
Controls are not functional in Hammer, as its a transient analysis software. But you can use the patterns, below is information on using patterns in Hammer.
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/9735.how-do-i-mimic-a-control-in-hammer
Sushma Choure
Bentley Technical Suppport
Claudia,
If you've used a transient operating rule on your valve and the closure results are not as you expect, it could be due to a problem with the valve configuration. Here are two related articles that may help:
Gradual closure not occurring when using valve operating rule
Modeling Reference - Valves [TN]
