Dear Bentley
I have a problem with my model, I have 10 FCV in my model (1 fixed+9 with pattern)
the duration of simulation is 72 hours (3 days)
I want to make 7 of them active for day 1 only
another one for day 2 only & the last one for day 3 only
I make a pattern for 3 days as shown in images
and I give each FCV the pattern of its day
the issue is some FCV is active (has flow) some times more than setting flow in time that I don't want the flow to pass
through it.
another issue that I have storage ground tank that I want to store water in it only without flow out from it I make the inlet pipe has check valve that make the flow go to tank only (tank starts with percentage full 50%) I found the tank empty in some hours I checked if the tank has a demand and found that there is no demand on tank
so how and where the tank is emptying ?!!
thanks a lot and sorry for taking long
Craig Calvin
Bentley Technical Support
It will certainly be very helpful to have a copy of the model for troubleshooting. One general note in the meantime - make sure you aren't using a FCV to block the only path of flow to set demands. If there are only demands downstream of a FCV (no tank or reservoir) and the sum of those demands is greater than the FCV setting, the flow will be forced through the FCV, to satisfy those assumed demands.
Check your user notification list for ill-conditioning and/or network unbalanced.
