hi
we have an existing irrigation network with multiple pump stations feeding the same network in many scenarios , due to newly developed areas the network had extensions and there was new demands required.
we have no data about this network.
the client requires the construction of a new Pump station and a discharge main to connect this new PS to the existing network .
this main will tie in with the network piping (not reservoirs )in many locations and the demand is given at each of these locations.
the question is : is it correct to create the model adding demands at tie in points and run the model to get pump head , i found the head around 17 m which looks very low as other connected PS's to that network have heads as 83 , 55 , 60 m.
note: we can't model the whole network (the existing and the new main) so i only modeld the new line with the new PS.
thanks
