anyone have an experience in calibration Hammer model?
Thx
Hello Fadel,
Could you please provide us more information on what kind of transient analysis or calibration do you want to perform using Hammer?
Here is some useful information for you to get started with Hammer, if you haven’t gone through it already.
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/10348.learning-resource-guide-for-new-user-of-bentley-hammer-v8i
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/3031.hammer-general-faqs
Sushma Choure
Bentley Technical Suppport
Dear Dr. Tom,
Thank you for your response, one of my student trying to model a simple
system, the system is for an experiment apparatus to determine the
characteristics of waterhammer and it is consist of the following:
1.Constant head tank,
2.test pipe connected to outlet at the base of the constant head tank,
the pipe is 3m length, 22 mm diameter, 0.9mm thickness, Young's modulus
215.3 GN/m^2, cross-section 0.3204x10^-3. The test pipe is in two
sections, with compression type unions and terminates with fast acting
valve with high closure rate.
the density of water used 1000kg/m^3 and Bulk modulus 2.05 GN/m^2,
attached is a hammer file for the model.
the experment results shows:
average flow velocity is 1.107 m/s, the calculate sound velocity 1290
m/s, the pressure is 13.5 bar, the time duration 6.875 mSecs
The problem is the model results does not match the experment result.
Could you evaluate the model.
Kind regards,
Fadel Dakhil
كتب Tom Walski في 2016-11-28 09:18:
> #outlook a {{padding:0;}} body{{width:100% !important;
> -webkit-text-size-adjust:100%; -ms-text-size-adjust:100%; margin:0;
> padding:0; background: #ffffff;}} .ExternalClass {{width:100%;}}
> .ExternalClass, .ExternalClass p, .ExternalClass span, .ExternalClass
> font, .ExternalClass td, .ExternalClass div {{line-height: 100%;}}
> #backgroundTable {{margin:0; padding:0; width:100% !important;
> line-height: 100% !important;}} img {{outline:none;
> text-decoration:none; -ms-interpolation-mode: bicubic; max-width:
> 100%;}} p {{margin: 1em 0;}} a {{border:none;color: #0087c3
> !important; text-decoration: none;}} a:active {{ color: #0087c3
> !important; }} a:visited {{ color: #0087c3 !important; }} table td
> {{border-collapse: collapse;}} table {{ border-collapse:collapse;
> mso-table-lspace:0pt; mso-table-rspace:0pt; }}
> Message from Bentley Communities
> [AUTOMATED MESSAGE; IF THERE IS A LINK BELOW, PLEASE FOLLOW THAT IF
> YOU WISH TO RESPOND TO THIS COMMUNITIES MESSAGE.]
> RE: calibration hammer model [1]
> Tom Walski [2]
> Scott's advice is correct if you are trying to calibrate the
> underlying network model which you need before you get into the
> transient analysis. We also have a great deal of material on such
> calibration in our book "Analysis of Water Distribution Systems".
> If you are trying to calibrate the transient aspects of a HAMMER run,
> you need data collected at a very fine time resolution. Data from an
> ordinary SCADA system or data logger may not be sufficient. There are
> special loggers than record pressures at a fraction of a second time
> interval that you would need.
> Once you get this data, if the model doesn't match the field data, you
> adjust model input to match the field data. One of the first things
> that users adjust is wave speed since the actual wave speed is often
> different from the theoretical speed.
> Did this answer your question?
> Verify it as the answer [3] or Reject it as the answer [4]
> View online [1]
> You received this notification because you subscribed to the forum.
> To unsubscribe from only this thread, go here [5].
> Flag [6] this post as spam/abuse.
> Links:
> [1]
> communities.bentley.com/.../393364
> [2]
> communities.bentley.com/.../e6d13ed9_2d00_5d63_2d00_4cf6_2d00_9780_2d00_44e709cf4cbb
> [3]
> communities.bentley.com/.../verifyanswer
> [4]
> communities.bentley.com/.../rejectanswer
> [5]
> communities.bentley.com/.../mute
> [6]
> communities.bentley.com/.../393364;AbuseContentTypeId=f586769b-0822-468a-b7f3-a94d480ed9b0&AbuseFlag=true
