Hallo,
after running an Simulation/ Analysis, there are no results in the felx tables ( velicity/ flow). Where can i Change this Problem, an woh can I see these results, because there are no error message.
Thanks for your help.
Hello Felix,
If validating and computing the model doesn't return the velocity and flow results, and there aren't any user notifications returned, then it would be helpful to take a look at your model. There are two options for sharing your model on Communities, whichever you choose please be sure to zip your files first. The first option is to attach the zip file containing your model to your reply on the forum using the Advanced Reply Editor (you'll find the link below and to the right of the reply box). If your data is confidential please use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley employees. Please be sure to reply on this thread with the name of the file after it has been uploaded.
Craig Calvin
Bentley Technical Support
