I have upgraded to select series 5 from select series 4 in SewerCAD and StormCAD. It used to be possible to select multiple columns in a flex table by holding the ctrl button and copying the data to i.e excel sheet. And also it was possible to use ctrl+shift+arrows to select desired columns or rows from start to end. However, in select series 5 these options are not applicaple. Is there a way to solve this problem or is there any patches for the solution.
Thanks in advance.
Emre.
Mark
Emre,
Regarding selection of a column - to do this, right click on the header and choose "select column". Then, click the copy button at the top. You can read more about this here:
How to Select a Column in Flextables and Other Places
