On roadways with median barriers, it is very common to have inlets which are a single structure but which contain 2 grates which are hydraulically independent.
In the drawing below, notice that the surface flow for the two grates is completely independent but both feed the same underground network.
Hello Robert,
For part one, hydraulically you can use the approach mentioned in this article (which I just edited a bit to include pictures):
Modeling one structure with two inlets (grates)
Basically you would model it as two catchbasins with a short, "fake" pipe between them.
Now, this doesn't work out quite so well for a physical model in Subsurface Utilities, since there physically would not be two separate catchbasin structures. Perhaps you could model it as one catchbasin structure with appropriate feature definition for the appropriate physical representation, and set up the inlet to be equivalent to the two grates. Of course, each grate would have a separate contributing area, but you may be able to do a hydraulic analysis of the capacity for a range of storm events using approach #1, then set up a catalog inlet to use for the physical model that provides hydraulically equivalent results. (perhaps using the inflow-capture curve method).
If the contributing areas of each side of the inlet are significantly different, it could pose a bigger challenge, though that may depend on which results are important to represent in Subsurface Utilities (spread and depth?). I'll consult with some colleagues for further advice.
Robert Garrett Senior Consultant
www.envisioncad.com
The final solution is much more elaborate:
You need the first inlet to be complete in itself because sometimes there will be a total structure but only one inlet, such as high side super.
Then the other side needs to be a skeleton. This skeleton is not intended to be used alone because there is no vault. Hydraulically, it is complete, but for the 3D model, there is only a skeleton of a vault.
And you need a false pipe between the two.
More details coming soon on our web site (EnvisionCAD.com).
Robert
